How can I set a VIEW rotation center in Rhino, now the view rotation operation is suffering!
I don’t know if it’s my own problem, but to rotate the view (holding right mouse button) in Rhino is really suffereing from the first day I use it. In most cases I can’t rotate the view as my expectation. It seems the view rotation center is always the world coordinate system center (0,0,0). How can I set a customed view rotaiton center?
Thanks!
Hello - there are several things to check - in Options > View:
Also, in the Gumball menu, there is a setting to check - this (in my opinion) should be un-checked for predictable behavior.
i typically Zoom Selected (ZS) to reset the center
Thank you, Pascal, for your quick and detailed answer!
For me “rotate relative to view” works best.
I really regret that I should have asked the question in the forum!!!
Thanks a lot! Rotate about gumball works best for me just by selecting and object to rotate around!
great one, was struggling with a very uncontrollable view rotation on a larger scale file (architectural model). this re-centred everything nicely!
