How do I set my perspective camera view to default. When I rotate the camera my objects and world tilt and appear crooked in the window instead of rotating parallel to the c plane.
Hi Jesus - check Options > View page for the setting to ‘Rotate relative to view’ / ‘Rotate around World axis’. Does changing that setting make a difference?
Yup, thanks!
Hi Pascal Golay. I am using Rhino 5.0 and I’m not able to find ‘Rotate relative to view’ / ‘Rotate around World axis’ under optios command. Can you please help me with that?Thanks!
i just want give you alternative solution, maybe it will work for some user.
try this
- shift + alt + Right Mouse Button
- ctrl + alt + right mouse button
