How can I print the points with bigger size?
Hi guys,
I want to print the points in bigger size, but in print preview we can see the points are alwas in samll size, even though I change the print width.
Any suggestion and clue are so appreciated!
This is in Rhino:
This is in print preview:
point2
You can set the circle size in the print dialog:
However, I don’t see how to increase the width of the point outline.
Thank you so much, @Helvetosaur!
That’s exactly what I want.
Just a question: it’s possible to show the points as solid ones instead of hollow ones?
Have a nice day!
Yes, you will however need to change that in the display mode you are using…
The preview looks poor, but the printed result looks OK.
@Helvetosaur, you are an expert!!
Thanks again!
