doh0615
(Doh0615)
October 2, 2018, 3:26am
#1
How can i make pattern mash?
my goal is making this mash pattern
HS_Kim
October 2, 2018, 3:43pm
#2
Not quite sure because of your poor reference image resolution, it looks similar to Cairo pentagonal tiling.
Try to search the old Gh forum and you’ll probably find what you want.
https://en.wikipedia.org/wiki/Cairo_pentagonal_tiling .
akilli
(Ethan Gross)
October 2, 2018, 3:50pm
#3
If it is Cairo, then the Mesh+ plugin has a Cairo component.
Mesh+ is a set of user objects which enable a wide range of mesh editing, creation, interaction, and topology modification within Grassh
HS_Kim
October 2, 2018, 8:28pm
#4
Attached is an example using Mesh+ and Weaverbird plugin.
CairoTiling(Mesh ,Wb)_re.gh (19.2 KB)
anikolo
(Aris )
October 2, 2018, 9:07pm
#5
@doh0615 I am sure you just wanted a simple voronoi or tiling pattern, but unkowingly (probably) you came across a very interesting design:
@HS_Kim , You are probably the best user around but I guess even you would need weeks to do that!
