New here. And new to RHINO, great program loving it 3 days in
i want to create a solid that has several curves. A picture says a thousand words:
Essentially i want the second object from the right to have curved tabs like the curve on the right while keeping it one solid.
Any help would be awesome!
never mind,
I split the tabs off the flat surface then used the flow command to bent them, then i joined the bent tabs back to the “frame” after that i used the flow command on the entire closed solid to bend it to the final form
not the idea results on the top tab tho… I’m sure i can fix that
Well done, that is a good way to solve it!
