Hi everyone,
I wanna convert that Brep made with the component Edge Surface.
Screenshot_51|690x372
Also I don’t know exactly why that gave me a Brep and with all these subdivisions, If you know, please explain me.
So for solve my problem, How can I transform into a only one surface (or maybe maximum 4) ?
Files to download:
Terreno Stiep.3dm (2.5 MB)
teste oficina6.gh (85.1 KB)
There are a few things here.
First of all you can copy paste a screenshot into a post. The screenshot I pasted below is done with ctrl+Q in Grasshopper.
Second thing. Your definition relies on plugins which not everyone uses. I extracted the relevant part of your definition and internalized the bottom curve.
As you can see, there’s no need to use list item 4 times per curve to build your catenary curves.
Then the reason why your surfaces have so many divisions is because the result of the catenary is a polyline. You can rebuild the polyline into a degree 3 curve with 10 control points for example. Then instead of creating 4 edge surfaces you can create one sweep2.
sweep2.gh (28.8 KB)
Thank you so much.
I will study your solution because I don’t usually use these components. But I think you solved my question ^-^
No problem. Ask when something is unclear.
If you’re unfamiliar with lists and tree structures, study the Grasshopper primer:
Grasshopper Primer — Mode Lab
I really appreciate that.
Yeah, absolutelly you solved my question. I think I understand but definitelly I will study this link.
Thank you so much again!
Perfect. Always happy to help someone
