I try to cap this model (in the file attached) but the program won’t to do it. Someone could me explain how can I do?
Many thanks,
Nicolaasmodel.3dm (246.1 KB)
Many thanks,
You have two open faces… You need to close one in order to cap it.
Cap only works on closed planar curves.
In simple terms, draw a single curve between corners and then select the other three edges and create a plane using _PlanarSrf
Once you’ve joined the parts you can cap it.
Andy
Or use EdgeSrf
on those two edges. Then join the result with your object and use Cap
to close it off.
many thanks
