Can someone help me figure out why i cant cap this model? I used SelOpenCrv found the issue tried some internet troubleshooting and couldn’t get anywhere. It looks to me like the curves all touch. But there has to be points that don’t touch here correct? otherwise id be able to cap right? joining a solid body is still confusing to me. I join the body and it says its created one closed polysurface. How is that not simple?
The bottom curve is not planar. Select it and try _PlanarSrf:
Since it is not planar there can be no cap. And the naked edges don’t help either. And you need to flip your polysurface after fixing the issues before you cap.
addendum: the front surface of your object is overhanging here
I fixed the front surface but im having trouble with the points. Can you dumb that down for me? like hoe do i get the points stacked in the first place? that happens to me a lot. I cant select and delete them so i must have to join the m somehow?
