When selecting an object with the layers panel viewed, that the layer of the object becomes highlighted and is brought into view in the layers panel
Video explanation
Video explanation
How to make this option work? I often have over 100 layers in one project. It would be so helpful to select an object, and the layer is highlighted in the layers panel. Would sure increase my work speed.
Until this is available, are you aware that you can select the Object’s layer from the Tools menu (via the Hammer icon) at the top of the layers panel?
No, I was not aware of that command. Thanks for the tip. That helps in the work flow.
