Select layer
When we select an object, the layer panel in the statusbar shows which layer it’s on.
In the panel I want this layer selected (blue background).
For now this helps a bit:
! _-OneLayerOn o _pause _Undo
This makes the layer active, not very wanted.
Also the layer is not selected.
What can I do to select the layer only and not set it active?
Hi Charles -
In Rhino 7 and before, there’s the Select Object Layer option from the panel:
In the Rhino 8 WIP, additionally, there’s the HighlightObjectLayers command.
Thanks Wim, I didn’t know that…
