Looking for an option to find / show layer / sublayer when selecting objects. Is there one?
Thanks a lot! ![]()
If that solves your problem, please click the Solution button.
This way other users will know the topic is solved.
Hei Øyvind -
A few more options:
- When you select a single object or multiple objects on the same layer, that layer will shown in the
Propertiespanel - You can select which information is shown in the field to the right in the status bar by right-clicking that field and making a selection. You’d need the second from the top:
Selected object layer - You can click the
Toolsbutton in theLayerspanel and then selectSelect Object Layer - In Rhino 8, that tool has gotten a new command to do the same:
HighlightObjectLayers
Cool! Thanks!
