Hi guys,
Just wondering if someone could walk me through the WIP stl export settings?
They have changed from R7 and I can’t get results that I am used to.
I can export from R7 but thought it was worth asking.
Here are R7 and WIP export settings window pics side by side.
R7 settings are from a Kyle Houchens tutorial back in the olden days…
make sure to set
“Maximum distance edge to surface” to something close to your production tolerance and rougher then the document tolerance.
(don t set it to 0.001 if this is already your document tolerance)
0.01 is more then enough for most 3d-Printing.
maybe post a screenshot or sample file - and target usages of your data.
then it s easier to tell you, which artefacts can be reduced by which parameter.
Thanks Tom,
I read through the docs.
I’ve just face palmed and realised the setting fields are just moved around and I haven’t taken the time to look at it properly.
I’ll try now to see if I can get the meshes I am used to.
Cheers,
Nick
