It looks like curves are not printed with a dash line. In the attached example all the solids are printing with a dashed line, but lines underneath (marked in red) is not. Anyone had this issue? The underpassing lines are in a block if that matters.
Hej Michael -
It’s impossible to troubleshoot such issue from a picture. Please post both the output of the Rhino SystemInfo
command and a 3dm file that shows an issue.
Found some time to set up an example I can share.
Attached is systeminfo, Example of print, Rhino file with example, export of the display style I am using. Let me know if you need more.
It might be a setting I have wrong, but I can’t figure it out. The problem seems to be related to curves behind objects. The surface and solid objects seems to be doing fine.
hiddenlineissue.txt (3.0 KB)
HiddenLineIssue.3dm (62.8 KB)
Pen Plus - Hidden.ini (14.2 KB)
continuous…
Second language. Grammerly wasn’t installed on the new computer.
Hej Michael -
Thanks, yes. For the time being, you’ll have to turn off hidden lines in the display mode for occluded curves to be clipped by objects.
I’ve put this issue on the list as RH-82576 Print: Vector Print does Not Occlude Curves
