Hello!
I am trying to create a structure of Hexagons. At the exit I want to get a mesh.
At the moment, I have managed to make a structure with quads only.
I am using a “SimpleMesh” but it cannot be use polygonal hexagons - it needs quads.
I’m stuck on this, and don’t know how to fix the problem.
I will be very grateful if someone can help me.
It’s great!
Is it possible to ask that the extrusion be not in the form of a cone, but would be created in the form of a lens with a closed hole at the bottom?
Try to place spheres on your cylinder using lunchbox Hexagon Cells and move them off along the surface normal directions a little bit, and do boolean difference usingSolid Difference.
As a result, I will receive a NURBS polysurface. I do not need it.
I just need to smoothly (like linse) close the holes. I am failing. Can you help me?
