Hello why in this example is it not possible to apply a hexagonal grid to a surface with straight edges? I have tried two methods and neither work.
Hexagonal grids.gh (54.7 KB)
Hi @k1624016,
Well it works, but on the untrimmed version of your surface! LunchBox components usually only work on untrimmed surfaces. You have to come up with a cleverer way to achieve your goal here.
Here’s one approach that should work with your surface:
However, one drawback is that not all cells remain hexagonal.
So how would you go about getting a similar result to what you get on a untrimmed surfaces? I’m trying to achieve all hexagons.
I don’t know if that’s possible, since the LunchBox component also needs a rectangular surface to work. Yours has a pentagonal shape. It may thus only be possible to approximate the surface, but you are going to lose the exact surface boundary.
Hexagonal grids 02.gh (21.1 KB)
