Hi, I need help fixing these lines, I’ve tried the crease command but I want to keep my outside lines curved and creasing them would give me a sharp corner.
Please try to use RemoveCrease to remove this sharp corners,
- Run '_SelectionFilterVertices in command line of Rhino
- Run RemoveCrease and select these sharp corners.
Please share this 3dm if you still can’t remove it via following steps above.
