I taught myself Rhino a couple of weeks ago for a university project.
Now I am almost finished but I cant solve one problem with naked edges…
My object is a small glass container. I shelled it and out came a not solid object. (maybe thats the problem to begin with). The bottom part inside wasnt closed so I deleted the broken part inside, drew some new curves and wanted to do a Sweep2 to close the edges.
But this one part just doesn’t close and I really don’t know what to do.
I would be really really happy if someone could help me.
I tried removing the curved surface between the naked edge and the middle round surface and then made a new surface using BlendSrf (Continuity) with no naked edges after joining it all together.
I am just trying it now and did you explode it first ?
Because the problem is that when I explode the object to delete the curved surface, than the edge at the bottom of where the curved surface was is split into many small curves…
I held down CTRL-SHIFT and selected the individual surface while it was joined into the solid, and then I just deleted it. That’s all.
Edit: If BlendSrf doesn’t close the solid after that, try increase tolerance to 0.0001 (from 0.001, which I did from start (I forgot to mention that, but BlendSrf may work fine anyway)
