Help with Cap
I’m having trouble capping this polysurface.
I thought I was careful keeping the curves planar before surfacing, but maybe not.
File attached. Thanks in advance.
–carl
Urn Rounded.3dm (406.9 KB)
Yep, the opening you’re trying to cap is just slightly off-planar. I fixed it by going to the right view and sub-selecting that whole bottom edge with a fence selection, then running SetPt and zeroing out all the points in the Z axis. Then Cap will close it off just fine.
Urn Rounded CAPPED.3dm (474.6 KB)
Thanks - I just fixed it another way before seeing your reply. I’ll check out fence selection.
yep.
please @Carl_Mesrobian mark Mark’s post as solution, so others don t need to dig in the topic.
