How to cap curved polysurface?
Hi :slight_smile:
I want to close a curved polsurface and it doesn´t work with the command “cap”. I think it is because the part which I want to close is not planar.
Do you know how I can close and join the surfaces?
Thanks in advance!
cap is only for planar edges (edges that are flat towards each other). use Loft with the two long/curved edges then use Join on everything.
Thank you so much. It worked out!
