Help with Bongo Look Along Z Up
Hello. I am trying to get an object to follow a path that goes back and fourth across the x and z axis as it goes up. When I attach the object to the path it’s works great when going to the right but flips upside down going to the left. Is there a way to change orientation in a simple constraint or turn a simple constraint into keyframes to adjust? Not sure what to do. Using Rhino 7 and Bongo 3.
Thanks
Would you be able to post an example model so we can have a look?
