Hi! Everybody
Bongo with a car from the VRay assets.
I try to constraint Look Along Curve. Could you explain to me why the car is rotating, as you can see at see end of the curve?
I try to change the axis, gumball. Nothing helps.
Attachment enclosed.
If you change the Constraint to be Look Along Z up (instead of Look Along Normal) and make sure the Z axis on the Bongo pivot in the car is pointing up, the problem should be solved.
