Would anyone be able to guide me recreate this parametric facade pattern in GH? Thank you
What do you mean by Parametric? That is a broad term when looking at an image like this.
As an example, i would like to create a similar pattern of vertical louvres for a given surface. The model attached was created using the TweenCurves command, but i do not know how to recreate the negative spaces between the vertical louvres as in the initial example. I would be grateful if anyone can help me. Thank you
Facade.3dm (2.5 MB)
Just create a surface representing the blobby shape and slice it in Grasshopper or even directly in Rhino. Nothing can beat modifying surfaces for explicit design control.
