How can I Create a Parametric Facade of Skyscraper
Hello, I am new to grasshopper, so I had this idea for a tower facade as shown in the image (was done in Rhino), i want to make it parametric by using grasshopper like able move the curve location. If you could give me some hints on which components i could use to develop this I would be greatful. I also attached the model i did in rhino for reference.
Thank You in advance
Exp_.3dm (2.5 MB)
How did you produce the curved surface from the curves?
Looks like all four are the same in a polar array?
P.S.
tower_2024Feb18a.gh (516.0 KB)
I used patch which is not working out, yes all four surfaces are the same, what i wanted to do is to create the frame lines in grasshopper itself so that i can explore various options like in the video
Would be most helpful if you posted some GH code instead of that brief video clip?
And that video shows GH, not how you did it in Rhino? Which was my question…
P.S. I realize we probably live in very different time zones? But only one post per day each doesn’t work for me.
