hello i am a student and i need to do this facade with grasshopper someone could help me pls
i have the 3d model of the building i link also the script.
LZ’s Love spa Pannelli.gh (46.1 KB)
no that was a test I was doing
no my main problem is that I have to make the panels follow a line I made the holes if you give me a moment I’ll make you a rhino file with the elements
Base.3dm (28.0 KB)
basically I have to redo that facade following the line I attached
rhino inside yes at the moment it is useless they were some tests that I was doing because afterwards I have to import the facade on revit
