Help in Tensile architecture
Hello, i am trying to create tensile constructions with grasshopper and, especially, kangaroo plugin, like frei otto’ s work. I created this file that i have some surfaces as input, and some points on them to lift. Despite the grasshopper works good, every time in one of the surfaces the program can;t read properly one point (one of the 4 edges of the specific surface). I checked all the point lists etc. but i can’t find the glitch.
Edit: I realised that the problem, perhaps, is the fact that mesh corner component fails to take the right points. I am trying to adjust the angle to “filter“ the points i want but i can’t do it correctly so far.
tensile-construction.gh (30.8 KB)
tensile-construction Edited v0.gh (27.4 KB)
thank you very much for the solution! it’s really helpful!
hey! those days I was experimenting in what form i want etc. I, also, create and circles that can go up and form an interesting surface. The problem is that i saw some fails in the smoothness of the surface. I tried to change some properties like subdivision etc. but i couldn’t fix it. is there a way to avoid those errors?
tensile-construction2.gh (21.6 KB)
If you are pulling parts of the membrane to circular boundaries, it will help if the topology of the initial mesh is designed to fit this. Here’s a simple example for a single opening:
circularopeningmesh.gh (15.4 KB)
