Display scattered
Hello Rhino fam,
I’m working on a very small object and when zooming in the objects/surface feels they are colliding together. What settings should I adjust to have better quality previsualization?
Thanks!
Are you using rhino v7 or v8?
please run the systeminfo command and post the report here.
Hi Kyle, here it is:
Windows 10.0.22621 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: LAPTOP - Plugged in [80% battery remaining]
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 2-22-2023 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 4080 Laptop GPU (NVidia) Memory: 12GB, Driver date: 7-12-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 536.67
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-12-2023
Driver Version: 31.0.15.3667
Z-Buffer depth: 24 bits
Total Video Memory: 12282 MB
you truncated it a bit… v7 or v8?
Rhino 7 SR12 !
I also increase the mesh setting to 0.002 but does not improve significantly.
SR12 ?
The current version is SR32.
You should probably look into changing the detailed settings.
If you upload a simple 3dm file, it’d be easier to help.
