Help grasshopper plug in fox
Hello! I need help, I’m looking for someone who can teach me how to use the fox plugin through a complex geometry that I already have modeled in rhino, so that it can do iterations that respond to rules and create a model of the union of the pieces. I am attaching my file, examples of what I want to achieve, and a picture of what I have that I did manually :frowning:
RHINO FOX.3dm (2.7 MB)
Did you try to download example files?
Yes, I tried, but it didnt work out. Do you know how? can you help me out?:frowning:
Example files still works (even after 2017).
These are inputs:
  • Object geometry
  • Planes on that object that must point outwards
  • Volume
It is a Plane to Plane transformation procedure that iteratively checks collisions.
Fox_02_Tile_Aggregations.gh (21.8 KB)
Hi MR.Vestartas
i am so grateful for the great add-ons NGon,Fox,OpenNest and so on that you made for community.hope they port to grasshopper for always.
i am trying fox and i don’t know how to make laser cut stripe with added joint edge part with hole that you done in the image, may i ask if you can show me the way please:
fox_sample.gh (11.1 KB)
I think this code originally comes from inflated restraint project: Inflated Restraint - petrasvestartas. It was a good learning experience from guys at CITA. Original implementation I learnt from Anders. And again this plugin was done in 2017, I did not touch it after that workshop, so it is up to you how you use it. Also check Ivy plugin that does a similar thing.
The balloons had polygonal subdivision after remeshing:
unroll.gh (24.6 KB)
And the one you mentioned was a triangular mesh:
For sure you have to do yourself the fabrication preparation yourself with indexing and holes…
so great,Thank you so much.
Hello, could you please help in this error
