Have worked through a few online courses I am now starting to use Grashopper.
I’ve installed and worked through several of the examples in the ‘Panelling Tools’ plugin documentation… but I can’t get this to work… Can anyone point me in the right direction ?
I’ve installed ‘shapediver’ and used the bitmap to link to a bitmap… and then converted to mesh and then deconstructed… but i get the feeling I am missing something obvious ?
please post the .gh definition / file so it s easier to help.
sure… here it is fwiw.
TBH, I’m just trying to work out what/how that ‘rhino logo graphic’ in the excerpt from the panelling tools manual is created / used ? the below grasshopper is jut my best effort *and it’s obvs not correct
Bitmaps_Attractor.gh (28.9 KB)
Too many plugins I don’t have to open that file so no idea what vector those points are moving along. Here’s a vanilla component example moving them up.
image.gh (39.8 KB)
Thank you
How do I achieve this ? what is it ? how do i create it ?
edit : oh it’s an image sampler (text was obstructed so i couldn’t see at first)
Thank you !! that’s all I needed
Open the attached code. It’s the image sampler node. Double-click inside it.
yes thanks, really neat and clean solution. Thanks for taking the time to create / post. Really helped me understand what’s going on
