Hi All,
I’m trying to model a certain type of origami that changes it’s shape when flexed. Please check the first 30 secs of this video which shows the behavior of that shape.
The problem I’m facing now is that between each two tetrahedron there a certain folding angle which somehow relates to the angle between the following one. So if the angle between polygon 1 and polygon 2 is controlled by slider, what would be the equation that relates that to the folding angle between polygon 2 and polygon 3 ? Right now the way I do it is to adjust the second angle manually each time I change the first which is definitely wrong. Please see the attached image and the GH file below. Thanks!
QUESTION.gh (18.4 KB)
