Hello Everyone,
I am trying to build a construction with origami.I got the inspiration from the video below.I am almost near to what I want to achieve.
As seen in the video above, I want the orange marked corners to also move inside when it collapses, I am able to move the middle points in the Z-axis but not able to move those corners inside. Maybe a little help from you guys can help me achieve this! Furthermore, I want to control the opening with the point attractor, closer the point it closes the geometry, Furthest the point it flats the geometry!
Origami Geometry.gh (17.4 KB)
Hello, I made a workaround! it works fine for one hexagon! When I try to apply it on multiple hexagonal cells it goes weird! I think there is a mistake in grafting and flattening the lists! I tried but I can’t get what’s going wrong in this! Please help!
Origami Geometry Re_V1.gh (18.8 KB)
A little more edited one! But the same problem persists in this one too!
Origami Geometry Re_V2.gh (21.4 KB)
@HS_Kim @laurent_delrieu @Joseph_Oster @DanielPiker Maybe you guys can help me with this please!
This is a different example to create folding from polygon with any number > 3,
and your example i think it is available in the forum.
polygon_folding.gh (19.8 KB)
Thank you for the response @anon39580149. I like your script and your inputs! Could you please address the link to that similar example in this forum!
Thank you so much @anon39580149. This really helped me a lot!
