Gumball orientation
When using the gumball and changing the orientation from Cplane to object, nothing happens? There is no change whatsoever. The gumball keeps the same orientation? Is there another setting that I should be looking at?
Thanks,
Rick
Hi Rick - it depends on the object - many objects have no inherent plane, and some do - planar curves, and surface, Extrusion objects, but not polysurfaces for example, or meshes. When Gumball cannot find a plane on the object, it reverts to CPlane. Multiple objects in a selection will also use CPlane.
Thanks Pascal!
Good to know.
Cheers,
Rick
