Gumball Dragging Objects Incorrectly – Snapping Randomly Nearby
Rhino Version: (Rhino 8)
Acer Nitro 5 32GB ram
I’m experiencing an issue with Rhino’s Gumball where dragging objects causes them to jump unexpectedly, seemingly snapping to the left or right a set distance anytime I try to drag any object, or curve This happens across all files, and none of the usual fixes seem to help. This is occurring with Grid Snap and OSnap turned off.
The issue is solved when I switch back to Rhino 7, but I would prefer to use 8
Hi @Joseph_Donaher
Pls run _SystemInfo in Rhino and post back the results.
Is this behavior happening with both grid snap off and snappy dragging off in Gumball settings?
turning Snappy gumball off fixed it… Thank you. I am curious how it turned on seemingly randomly though
