Gumball Disappears in 7 & 8
I see the disappearing gumball is a recurring problem. I changed and reset a few Nvidia settings today
The 4090 shows in devices but no Intel graphics show. The gumball appears then disappears when the mouse gets close in both 7 & 8. With a box I see the centre free movement dot, with a SubD I see red and green dots. I can also invoke the numerical gb input. I have reset gumball and the Nvidia settings. Rhino was not in the Nvidia group of apps, I added it and have now removed it. Nvidia was not in the global list, I added it.
The gumball works OK on other CAD programs and on my laptop. Can you suggest any fixes?
Thank you.
Rhino 8 SR1 2023-11-21 (Rhino 8, 8.1.23325.13001, Git hash:master @ 8a4a437248efac5d9cb04d3904481b83e4c23a64)
License type: Evaluation, build 2023-11-21
License details: Cloud Zoo
Expires on: 2024-02-02
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 1.3e+02Gb)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 4090 (NVidia) Memory: 24GB, Driver date: 12-22-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 528.02
- Windows Main Display attached to adapter port 0
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-22-2022
Driver Version: 31.0.15.2802
Z-Buffer depth: 24 bits
Total Video Memory: 24564 MB
C:\Users\gwm10\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\Bella (813de3fb-18eb-405f-bfcd-b0b4d3da91fb)\23.4.0.0\bella_rhino.rhp “Bella” 23.4.0.0
C:\Users\gwm10\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\D5Conv (e0d5e210-02f6-4ee9-a2b0-1675e225d958)\0.10.1.0001\Rhino 7\D5Conv.rhp “D5Converter for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.1.23325.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.1.23325.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.1.23325.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.1.23325.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.1.23325.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.1.23325.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.1.23325.13001
C:\Users\gwm10\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\PanelingTools\2021.3.2.446\PanelingTools.rhp “PanelingTools”
Does this happen in all display modes? Are your display modes more or less default?
Dunno, maybe update the Nvidia driver for good measure - looks like it’s a year old - and if that doesn’t help maybe try temporarily disabling the two plug-ins Bella and D5…
Driver says it’s the latest, hard to believe but… Disabled Bella and D5, no change. The GB works if I remember the position… What display modes? Render V wireframe? No difference.
Yes, especially for a card as recent as a 4090… did you go directly to the NVidia driver site? My old Quadro P2000 here has updates to 537.70
What is the point of having a powerful video card and year-old drivers? (or beyond).
Video drivers need to be updated, this solves many graphic problems. I often read similar posts, same problems… :man_facepalming:
Updated drivers to ( Driver date: 11-29-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 546.29)
The GB is a little better, can select a function if the cursor does not pass over something else … But if I touch a function like scale x then change to scale y, it still disappears. MOI, Zbrush, Maya all work fine.
.NET 7.0.0
Primary display and OpenGL: NVIDIA GeForce RTX 4090 (NVidia) Memory: 24GB, Driver date: 11-29-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 546.29
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 11-29-2023
Driver Version: 31.0.15.4629
Working after changing NVIDIA Settings, can’t be sure which one cured it.
