Gumball disappears as mouse moves near it
I’ve referred to all the previous threads regarding this topic but could not apply a relevant fix.
Running my copy of Rhino on my Desktop with an Nvidia RTX 2070 Super and also on my laptop which is barebones. This problem only exists on my desktop- I went some time without using Rhino and when i got back, this problem reared itself.
I’ve updated all Nvidia drivers to the latest, updated all of Windows to the latest and Rhino 7 is running the latest.
The problem is : when the gumball is activated, it IS visible but as soon as i move my mouse anywhere near the gumball it disappears. but weirdly enough if i click the exact spot where the z arrow for example is, the gumball z arrow gets pressed. So its some weird display issue that makes the gumball disappear but still work.
This problem does not exist when using Rhino on my laptop.
I’m writing this topic only because i’ve tried everything from the previous topics and see no difference.
Thanks in advance
hi @Shamil_Othayoth pls run _SystemInfo in Rhino and post back the results
Rhino 7 SR37 2024-4-16 (Rhino 7, 7.37.24107.15001, Git hash:master @ d2e42f70b9d3aa58f6053e2998a0db2abcd7555b)
License type: Commercial, build 2024-04-16
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 31Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2070 SUPER (NVidia) Memory: 8GB, Driver date: 10-15-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 566.03
Secondary graphics devices.
AMD Radeon™ Graphics (AMD) Memory: 1GB, Driver date: 6-25-2024 (M-D-Y).
> Accelerated graphics device with 5 adapter port(s)
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-15-2024
Driver Version: 32.0.15.6603
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.37.24107.15001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.37.24107.15001
I seemed to have solved it.
Tinkering with settings in the Nvdia control panel, it appears to be an Antialiasing issue.
Turning off the following settings:
Antialiasing FXAA
Antialiasing Mode
Gamma correction
from the Nvidia control panel fixed the disappearing gumball.
I’d be grateful for a break down of why this happens?
Thank you
Let me try if I can repeat the issue by turning them ON
Edit: It’s not entirely clear from that description how it was set.
Glad to hear in any case that you solved it for your system.
I’m in doubt though if these settings could be responsible for it. Do you get your issue back if you change the settings again?
