I have read the two threads, 2013 Strange Gumball Behavior and 2019 Gumball disappears. I have the same issue on an old laptop as per the system info below. I can use the invisible gumball! It appears when making a selection and can see it if I move the mouse away from it; but if I move toward it, it disappears. Drivers and Rhino version up to date, Intel graphics disabled. Other recent nonsense includes the desktop icons moving to the secondary display which is a WACOM Cintiq Pro 24. I have recently installed a flight simulator and a joystick and logitech multi pc keyboard and mouse. But I have tried to disable / undo as much of that as possible. The gumball works fine in ZBrush, MOI, and Modo. I also have selection problems on SubDs ands the selection box is not visible. Same using mouse or stylus, Wacom or PC screen. Thanks for any ideas on a solution.
Rhino 7 SR18 2022-5-4 (Rhino 7, 7.18.22124.03001, Git hash:master @ b2a1120bcb32e1f6da66a421cd7162a18a9f0cd9)
License type: Commercial, build 2022-05-04
License details: Cloud Zoo
Windows 10.0.19044 SR0.0 or greater (Physical RAM: 32Gb)
Secondary graphics devices.
NVIDIA GeForce GTX 1060 (NVidia) Memory: 6GB, Driver date: 10-10-2018 (M-D-Y).
Intel(R) HD Graphics 630 (Intel) Memory: 1GB, Driver date: 10-1-2018 (M-D-Y).
> Integrated graphics device with 0 adapter port(s)
- There are no monitors attached to this device. Laptop lid is probably closed
ATTENTION:
An integrated accelerated graphics device exists and is attached to a monitor, but it’s not being used by Rhino.
- Recommended: Use Windows’ Display Settings to configure one of the other monitors to be the “Main Display”.
- Any hardware configuration or cabling changes you make will require that you restart Rhino.
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-10-2018
Driver Version: 25.21.14.1634
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.18.22124.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.18.22124.3001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.18.22124.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.18.22124.3001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.18.22124.3001
C:\Users\GWM2\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2021.3.2.446\PanelingTools.rhp “PanelingTools”
