Guitar Neck: MatchSrf Between a loft and a trimmed Surface?
Hello Folks, i have a loft and a trimmed surface that i got as a result of using XNurbs, but there’s gaps and not so smooth transitions when using Zebra. Can you MatchSrf These 2 different types of Surfaces? What would you reccomend to do in this case? The red surface is trimmed (XNurbs) and the Blue is a Loft. Thank you
Jarius Neck 4 String.3dm (853.6 KB)
You can MatchSrf the untrimmed edge of a surface to the trimmed edge of another surface, but you cannot use MatchSrf to modify a surface along a trimmed edge.
Blendsrf possibly?
Thanks David. If i still can’t do the Match, what could be happening?
Thanks Greg, ok i will try that.
The surface created by XNURBS has trimmed edges so it cannot be modified by MatchSrf.
You can trim the red surface and then use BlendSrf as suggested by Greg.
Hello - the blue surface is currently trimmed (Turn on points to see this) If you ShrinkTrimmedSrf you will be able to match the blue to the red.
Hey Pascal! Thankyou very much. I did it and it worked!!
