I would like to use MatchSrf but the surface is trimmed (I can`t select and use it in MatchSrf).
So I`ve tried to do ShrinkTrimmedSrf:
It was still bad.
Next, I`ve tried to use ShrinkTrimmedSrfToEdge:
It’s still bad. MatchSrf still can`t select it and use it.
I would like to match that edge pointed with green arrow.
I think that after some manual shrinking process CP dots should be exact on the edge and then MatchSrf will work properly (I hope).
After that, I thought that I manually will move Control Points to their position and It won’t be needed to use MatchSrf on that surface.
But when I move points my edges are also changing their position. Is there any trick to fit that edge to the moved points or move the points to the exact edge (to fit the edge and points together in demanded place)?
How do you solve that because it`s popular problem I think.
Do you know any tricks for that?
