Hey Guys,
I am quite new to Grasshoper/Rhino. I tried to create an Torus like solid with voronoi mesh. I found an tutorial online and followed it, but there are some erros, I´ve tried to solve them but now luck…
Do you guys have an idea?
Thanks,
I fixed the errors by adding an cap. But the middle of the torus is also full with voronoi (maybe due to the cap) but I only want the torus. So it should look like an headband…
I just used Cap hole to test, up to you to make the geometry you want. This is classic Rhino Modelling. If I remember well you just have to join your torus with a cylinder.
I was able to generate the Voronoi strtucture, but there are some random sharp spikes. How can I change the Grasshoper file, that thoose do not occur.
Best regards,
Julian voronoi.gh (30.0 KB)
