hi i’d like to make some kind of contoured surface
so i made surface by contoured lines and move lines below,and
want to split the surface
but it seems it doesnt work
i used project curve on brep, it doesnt work too
anyone has idea to make that surface?
0525 contour.gh (55.3 KB)
Extrude surface downward. Use contour -> you will get closed curves.
move curve down. Loft initial curve with moved ones -> vertical surface
Shift initial curves. Merge initial curves with shifted ones. Create boundary surface from both curves -> horizontal surface
BTW don’t create always new threads.
Did you find a way to draw it in Rhino first ?
If you find a satisfying solution in Rhino, then you can try to build it in GH and have few parameters to adjust your model.
I did the modeling in Rhino :
[image]
The red parts will be easy because curves are closed, (nevertheless, you’ll have to deal with different curves on the same plane). But the blue ones are to be made from open curves, you’ll have to find a way to close the curves before anything else.
In your case, if you want to …
thanks tim i got this one
and ok i’ll update at old one next time
