So i have a offset curve that i want to convert to a surface.
I have already tried Boundary Surface and even Loft but it is not working.
Please can someone help me
You’d have to have closed planar curves for them to just ‘convert’ to surfaces in grasshopper (that is, when you go from a curve output to a ‘srf’ component) - anyway, you didn’t post your file!
trial grasshopper bench fail.gh (23.5 KB)
this is the grasshopper file am really sorry am really new to this
thankyou very much for replying
i tried but still didn`t find a way to make them planar curve
I didn’t mean to leave without a reply…holiday(s)…anyway, your file doesn’t come with the internalized objects, hence I see nothing in Rhino when I open your file - make sure you internalize the starting entities:
Best
Hi Rene
thanks very much for taking your time i totally understand
i tried actually another method and it work.
Instead of applying the geometry ( offsetted Curve ) directly to the surface of the Bench, i designed the texture ( geometry ) seperately and then used Surface morph to map the texture onto the surface of the Bench.
Thankyou for your time and comprehension and happy new year
