Grasshopper Make2D does not support points?!
This has to be a bug… How is that Rhino’s make2d supports points but GH’s doesn’t? Isn’t the component using the same method/function/command??
I was hoping to use GH’s Make2D component because it allows to input a tree, where each branch is individually projected, not the entire tree. I am not able to to this via Rhino’s Make2D because it would require me to make x50 individual Make2Ds, as my tree has about 50 branches…
Rhino and Grasshopper rarely use the same functions collectively. Grasshopper mostly uses Rhinocommon and the Grasshopper API.
It is using the functionality, I must just not be handling points. The component is focused on curves only as I recall. Not sure what it would take to add this functionality, if it’s a lot of work it may not happen for GH1 any more.
I hate it when you say that :confounded:
Hopefully it can be added without too much work.
David were you able to look into this, so that I know whether to lose hope or not :joy:
I looked into it but it would require the component to be significantly redesigned as currently all outputs are curve parameters. I don’t want to add a bunch more outputs for visible or hidden points. Couldn’t come up with a solution I liked, indecision led to inaction.
I’m not sure this is going to happen for GH1. If you have a suggestion on what the inputs and outputs should look like, I’m all ears.
I understand. Oh well. :sob:
I think that there is no need to differentiate the outputs in curve/points. Make the same output for both. If then you want to separate both you can filter them afterwards, or even before, duplicating the Make2D component.
As a side note, I also think the component should have a Boolean input, to recompute, instead of having the user manually click on the component. This would enable automation of the task.
