Make2d result is not correct
I noticed that in Rhino & GH some unwanted (hidden) curves appear as a result of make2d.
m2d.3dm (1000.7 KB)
not seeing that here… systeminfo?
can you share your GH def?
Hi Kyle,
I may have found the cause of the problem. the outputs of objects at different elevations are different.
m2d.3dm (3.8 MB)
You can also find the gh def below. The make2d component gives the correct output, but the output of the c# component has problems.
m2d.gh (1.1 MB)
