Hello everyone. I’m struggling with this. I have two untrimmed surfaces that share an edge of the same lenght (they need to be two I can’t merge them) and I want to apply an Hex pattern on both but for some reason the spacing of one is different from the other even if the division ratio is the same. Can someone help me figuring out why?
Lunchbox grids are based on surface topology
for instance, given a planar surface, when I move its internal control points the surface is still planar with same boundary, but the hexa grid is changing:
