Hello everybody, I was trying to create a hexagonal space frame like the first rendering, I offset the hexgrid and trying to link the list item points, however, the result wasn’t successful.
I wonder if I’m going on the right direction, please point me out if there is any improvment I can do.
Hex_from_srf.3dm (65.9 KB)
Hex_from_srf.gh (9.6 KB)
Thank you so much for your sharing. That’s really amazing you completed in such a clean and simple way.
I was trying a different way, first I made a UV grid and try to connect the points to make the pattern.
Then I tried to apply to a 3D surface, I offset the surface in order to get a 3D grid, but there’s always a gap between the surfaces.
I tried to connect the points but not able to flip the surfaces…
Attached my definition here for comment and suggestion, thank you!
Hex_from_crv.3dm (82.3 KB)
Hex_from_crv.gh (23.4 KB)
This could be another way. You can apply Surface Morph at the end of it.
Maybe, you can get some hint for your case of list management.
HexagonPatternFaacade_v2.gh (15.8 KB)
thank you so much! it really works well!
I’m now trying to apply your v2 to a surface, but i got a problem getting the reference box…
any solution about this?
It works well! Thank you so much for all your help!
