Hi, i have some issues with starting grasshopper for rhino8 (still working with rhino6) and i think it might be because previously grasshopper told me that there are loading issues. It said, that there are 2 files that do the same and i have to delete one. I did and afterwards it said, that the “python assemblyinfo” is missing. Now, every time i wanna start gh in rhino 8, it stopps loading the components when “gh pyton” is written down in the loading bar… Anyone had a similar problem? Thanks in advance for any help!!! developer Grasshopper Developer Rhino Developer
Hi Manuel -
I’d start with a “Repair” of Rhino 8 from the Windows Control Panel.
I tried but it didn`t work
Try launching grasshopper from the Rhino command line with GrasshopperLoadOneByOne and say no to 3rd party addons, if that is successful then relaunch Rhino and use GrasshopperLoadOneByOne to narrow down the conflict.
Thank you Japhy, it worked. The problem is somewhere with Elk and Capybara
I will delete them and try it again with the normal mode
