Rhino7 Mac crashes after putting a component on Gh canvas
Hello and greetings for the new year,
My rhino 7 on Mac crashes automatically once I put a component on grasshopper canvas, (Rhino file is few Mb, Gh doc is virgin/blank).
I tried with with different native components (Geo, curve, etc…)… same.
The same problem occurred on both versions. the one I have installed to check if the problem will be corrected… Version 7 (7.14.22004.01002, 2022-01-04) and the one before it.
Please fix this it is crucial for work !
My system info is here : Rhino 7 SR14 2022-1-4 (Rhino 7, 7.14.22004.01002, Git hash:master @ e3d354475c9d642213575609786a4b35ea48ca22)
License type: Educational, build 2022-01-04
License details: Cloud Zoo
Apple macOS Version 12.1 (Build 21C52) (Physical RAM: 32Gb)
Mac Model Identifier: MacBookPro15,1
Language: en-JP (MacOS default)
AMD Radeon Pro 560X OpenGL Engine (OpenGL ver:4.1 ATI-4.7.101)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 4 GB
Graphics: Radeon Pro 560X
Displays: Color LCD (258dpi 2x), HP Z23n G2 (96dpi 1x)
Graphics processors
Intel UHD Graphics 630 (1536 MB)
Radeon Pro 560X (4 GB)
Color LCD (1680 x 1050)
HP Z23n G2 (1920 x 1080 @ 60.00Hz)
USB devices
MOSART Semi.: 2.4G Wireless Mouse
Apple Inc.: USB-C Digital AV Multiport Adapter
Apple Inc.: USB3.0 Hub
Apple Inc.: Touch Bar Backlight
Apple Inc.: Touch Bar Display
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple: Headset
Apple Inc.: Ambient Light Sensor
Apple Inc.: FaceTime HD Camera (Built-in)
Apple Inc.: Apple T2 Controller
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswiftCloudKit.dylib
/usr/lib/swift/libswiftCoreData.dylib
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftContacts.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
/Users/ghalibouayad/Library/Application Support/McNeel/Rhinoceros/packages/7.0/ProRender/1.0.0.6/ProRender.Mac.V7.rhp “ProRender” 1.0.0.6
/Users/ghalibouayad/Library/Application Support/McNeel/Rhinoceros/packages/7.0/AMDDenoiser/0.5.0/AMDDenoiser.Mac.rhp “AMDDenoiser.Mac” 1.0.0.0
/Users/ghalibouayad/Library/Application Support/McNeel/Rhinoceros/packages/7.0/Bullant/1.5.11.0/bullant.rhp “bullant” 1.5.11.0
/Applications/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp “Import_OBJ” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp “export_xaml” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp “QuadRemesh” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp “export_OBJ” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp “Export SVG” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp “Export_DAE” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp “IGES Export Plug-in” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp “Import_SVG” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp “Export_AMF” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp “Import_DST” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp “PLY - Polygon File Format Export” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp “Import_AMF” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.14.22004.1002
I’m not seeing any issues. It looks like i’m a little behind on an OS update.
Do you have any grasshopper plugins installed??
Summary
Rhino 7 SR14 2022-1-4 (Rhino 7, 7.14.22004.17002, Git hash:master @ 44c836a8d73f3225924eb53459f7396f61924cec)
License type: Commercial, build 2022-01-04
Apple macOS Version 12.0.1 (Build 21A559) (Physical RAM: 16Gb)
Rhino is running in Rosetta2 on Apple Silicon
Mac Model Identifier: MacBookPro18,3
Language: en-US (MacOS default)
Apple M1 Pro (OpenGL ver:4.1 Metal - 76.1)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Vendor Name: Apple
Render version: 4.1
Z-Buffer depth: n/a
Total Video Memory: 10922 MB
Graphics: Apple G13X
Displays: Unknown (255dpi 2x)
Graphics processors
Apple G13X
Color LCD (1512 x 982 @ 120.00Hz)
USB devices
None
Bluetooth devices
None
None
Third party plugins
/Applications/Rhino 7.app/Contents/PlugIns/export_FBX.rhp “Export_FBX” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/Export_UDO.rhp “Moray Export” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_STEP.rhp “STEP Import” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoBonusTools.rhp “Rhino Bonus Tools” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/MeshTools.rhp “MeshTools” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/Import_X.rhp “X Import” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_LWO.rhp “Lightwave Import” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoLabsTools.rhp “Rhino Labs Tools” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_PDF.rhp “PDFReader” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/CreaseAngle.rhp “CreaseAngle” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_SLC.rhp “SLC Export” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_STEP.rhp “STEP Export” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_VDA.rhp “VDA Export” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_Points.rhp “Points Export” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/Export_XGL.rhp “XGL Export” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/Import_SolidWorks.rhp “Solidworks Import” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/Import_WAMIT.rhp “WAMIT import” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/MeshFromPoints.rhp “MeshFromPoints” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_3MF.rhp “import_3MF” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_IGES.rhp “IGES Import Plug-in” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_SKP.rhp “SketchUp Import” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/Export_CSV.rhp “Comma Separated Value Export” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_SAT.rhp “ACIS Export” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/Export_RIB.rhp “Renderman Export” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_VDA.rhp “VDA Import” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_RAW.rhp “RAW Triangle Import” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/Export_CD.rhp “Cult3D Export” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_STL.rhp “STL Export” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/Export_RAW.rhp “Raw Triangles Export” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/Export_X.rhp “X Export” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_LWO.rhp “Lightwave Export” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_Points.rhp “Points Import” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/Export_WAMIT.rhp “WAMIT Export” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/NamedPositions.rhp “Named Position” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/Export_GTS.rhp “GTS Export” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/Export_POV.rhp “POV-Ray Export” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/SolidTools.rhp “SolidTools” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/MPlane.rhp “MPlane” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_AI.rhp “Adobe Illustrator Export” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/Import_M.rhp “Import_M” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/Squish.rhp “Squish” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/Import_OFF.rhp “OFF Import” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/Import_SLC.rhp “SLC Import” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_VRML.rhp “VRML/X3D Export” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_3DS.rhp “3D Studio Export” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_ACAD.rhp “AutoCAD file import: import_ACAD” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_STL.rhp “STL Import” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/Import_DGN.rhp “MicroStation file import: import_DGN” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_3MF.rhp “export_3MF” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_SKP.rhp “SketchUp Export” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_VRML.rhp “VRML Import” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_FBX.rhp “Import_FBX” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/Export_X_T.rhp “Parasolid Export” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_ACAD.rhp “AutoCAD file export : export_ACAD” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/Import_GTS.rhp “GTS Triangle Import” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_PLY.rhp “PLY - Polygon File Format Import” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.14.22004.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp “Import_OBJ” 7.14.22004.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp “export_xaml” 7.14.22004.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp “QuadRemesh” 7.14.22004.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp “export_OBJ” 7.14.22004.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.14.22004.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp “Export SVG” 7.14.22004.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 7.14.22004.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp “Export_DAE” 7.14.22004.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 7.14.22004.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp “IGES Export Plug-in” 7.14.22004.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp “Import_SVG” 7.14.22004.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 7.14.22004.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp “Export_AMF” 7.14.22004.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.14.22004.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp “Import_DST” 7.14.22004.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp “PLY - Polygon File Format Export” 7.14.22004.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp “Import_AMF” 7.14.22004.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.14.22004.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.14.22004.17002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.14.22004.17002
Yes I am having several plugins installed. They never were an issue.
When I am launching grasshopper I am getting since almost a year component conflict (same existing somewhere else)… until I upgraded my Mac it worked okay… Do you think that might be causing the problem ?
I also attach here the problem report sent to Apple. Perhaps it contains the issue ?
Thanks
Translated Report (Full Report Below)
Process: Rhinoceros [2673]
Path: /Applications/Rhino 7.app/Contents/MacOS/Rhinoceros
Identifier: com.mcneel.rhinoceros.7
Version: 7.14 (7.14.22004.01002)
Code Type: X86-64 (Native)
Parent Process: launchd [1]
User ID: 501
Date/Time: 2022-01-06 11:59:54.3231 +0900
OS Version: macOS 12.1 (21C52)
Report Version: 12
Bridge OS Version: 6.1 (19P647)
Anonymous UUID: 058F18F2-92A8-9740-54C7-4B22B578699F
Time Awake Since Boot: 1000 seconds
System Integrity Protection: enabled
Crashed Thread: 0 tid_103 Dispatch queue: com.apple.main-thread
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Application Specific Information:
[ERROR] .NET STACK TRACE:
at AppKit.NSApplication.RunModalSession (System.IntPtr session) [0x00000] in <3d8c2e0da31b4784a40c7d9116ca5ede>:0
at Eto.Mac.Forms.ModalEventArgs.RunSessionInternal () [0x00000] in <1a95af7dc2f64d808332267a6d3af64d>:0
at Eto.Mac.Forms.ModalEventArgs.RunSession () [0x00000] in <1a95af7dc2f64d808332267a6d3af64d>:0
at Eto.Mac.Forms.ModalEventArgs.RunModal () [0x00000] in <1a95af7dc2f64d808332267a6d3af64d>:0
at Eto.Mac.Forms.MacModal.Run (Eto.Forms.Window window, AppKit.NSWindow nativeWindow, Eto.Mac.Forms.ModalEventArgs& helper, System.Boolean isSheet) [0x00000] in <1a95af7dc2f64d808332267a6d3af64d>:0
at Eto.Mac.Forms.DialogHandler.ShowModal () [0x00000] in <1a95af7dc2f64d808332267a6d3af64d>:0
at RhinoMac.Runtime.RhinoDialogHandler.ShowModal () [0x00000] in :0
at Eto.Forms.Dialog.ShowModal () [0x00000] in :0
at Eto.Forms.Dialog.ShowModal (Eto.Forms.Control owner) [0x00000] in :0
at Eto.Forms.Dialog1[T].ShowModal (Eto.Forms.Control owner) [0x00000] in <aef5e7e1bb2640c9893a9b349e471b33>:0 at Grasshopper.EtoExtensions.ShowDialog (Eto.Forms.Dialog1[T] F, System.Windows.Forms.IWin32Window parent) [0x00000] in :0
at Grasshopper.Kernel.GH_FontServer.GetFontSubstitution (System.String family, System.Single size, System.Drawing.FontStyle style) [0x00000] in :0
at Grasshopper.Kernel.GH_FontServer.NewFont (System.String family, System.Single size, System.Drawing.FontStyle style) [0x00000] in :0
at Grasshopper.Kernel.GH_FontServer.StringToFont (System.String text) [0x00000] in :0
at Sunglasses.Settings.get_Font () [0x00000] in <61c9be43de4441bca76dc82dff0b8dbc>:0
at Sunglasses.Drawing.PaintNames (System.Drawing.Graphics graphics, System.Collections.Generic.IEnumerable`1[T] objects) [0x00000] in <61c9be43de4441bca76dc82dff0b8dbc>:0
at Sunglasses.SunglassesMenuItem.Canvas_CanvasPrePaintObjects (Grasshopper.GUI.Canvas.GH_Canvas sender) [0x00000] in <61c9be43de4441bca76dc82dff0b8dbc>:0
at Grasshopper.GUI.Canvas.GH_Canvas.Regen_DrawMiddleGround () [0x00000] in :0
at Grasshopper.GUI.Canvas.GH_Canvas.OnPaint (System.Windows.Forms.PaintEventArgs e) [0x00000] in :0
at System.Windows.Forms.Control.Draw (System.Windows.Forms.PaintEventArgs events) [0x00000] in <436f4c5c24fb40bf904baec2882bf158>:0
at System.Windows.Forms.ViewHelper.DrawRect (CoreGraphics.CGRect dirtyRect) [0x00000] in <436f4c5c24fb40bf904baec2882bf158>:0
[END ERROR]
[LOADED ASSEMBLIES]
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Versions/Current/Resources/
Xamarin.Mac.dll
monostart.exe
RhinoMac.dll
Mindscape.Raygun4MacRhino.dll
Eto.XamMac2.dll
Eto.dll
Rhino.UI.dll
RhinoCommon.dll
lib/mono/gac/System.Drawing/4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
lib/mono/gac/System.Windows.Forms/4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
RhinoMacBindings.dll
Eto.CodeEditor.dll
ManagedPlugIns/Commands.rhp/Commands.rhp
Yak.Core.dll
ManagedPlugIns/Import_OBJ.rhp/Import_OBJ.rhp
ManagedPlugIns/export_XAML.rhp/export_XAML.rhp
ManagedPlugIns/QuadRemesh.rhp/QuadRemesh.rhp
ManagedPlugIns/Export_OBJ.rhp/Export_OBJ.rhp
ManagedPlugIns/RDK_EtoUI.rhp/RDK_EtoUI.rhp
ManagedPlugIns/export_SVG.rhp/export_SVG.rhp
ManagedPlugIns/MeshCommands.rhp/MeshCommands.rhp
ManagedPlugIns/Export_DAE.rhp/Export_DAE.rhp
ManagedPlugIns/export_PDF.rhp/export_PDF.rhp
ManagedPlugIns/export_IGES.rhp/export_IGES.rhp
ManagedPlugIns/Import_SVG.rhp/Import_SVG.rhp
ManagedPlugIns/BlockEdit.rhp/BlockEdit.rhp
ManagedPlugIns/Export_AMF.rhp/Export_AMF.rhp
ManagedPlugIns/RhinoRenderCycles.rhp/RhinoRenderCycles.rhp
ManagedPlugIns/import_DST.rhp/import_DST.rhp
ManagedPlugIns/export_PLY.rhp/export_PLY.rhp
ManagedPlugIns/Import_AMF.rhp/Import_AMF.rhp
ManagedPlugIns/RhinoCycles.rhp/RhinoCycles.rhp
ManagedPlugIns/RhinoCycles.rhp/RhinoCyclesCore.dll
ManagedPlugIns/RhinoCycles.rhp/csycles.dll
ZooClient.dll
ValidationClient.dll
Proxy.dll
CloudZooClient.dll
Newtonsoft.Json.Rhino.dll
websocket-sharp.dll
crypto.dll
jose-jwt.dll
ManagedPlugIns/RhinoDLR_Python.rhp/RhinoDLR_Python.rhp
ManagedPlugIns/RhinoDLR_Python.rhp/RhinoPythonHost.dll
ManagedPlugIns/RhinoDLR_Python.rhp/Microsoft.Scripting.dll
ManagedPlugIns/RhinoDLR_Python.rhp/Microsoft.Dynamic.dll
ManagedPlugIns/RhinoDLR_Python.rhp/IronPython.dll
ManagedPlugIns/RhinoDLR_Python.rhp/IronPython.Modules.dll
ManagedPlugIns/GrasshopperPlugin.rhp/GrasshopperPlugin.rhp
ManagedPlugIns/GrasshopperPlugin.rhp/Grasshopper.dll
ManagedPlugIns/GrasshopperPlugin.rhp/GH_IO.dll
System.Resources.Extensions.dll
ManagedPlugIns/GrasshopperPlugin.rhp/Components/System.Memory.dll
System.Runtime.CompilerServices.Unsafe.dll
ManagedPlugIns/GrasshopperPlugin.rhp/Mono.Cecil.dll
ManagedPlugIns/GrasshopperPlugin.rhp/Components/CurveComponents.gha
ManagedPlugIns/GrasshopperPlugin.rhp/Components/TriangulationComponents.gha
ManagedPlugIns/GrasshopperPlugin.rhp/Components/GalapagosComponents.gha
ManagedPlugIns/GrasshopperPlugin.rhp/Components/Galapagos.dll
ManagedPlugIns/GrasshopperPlugin.rhp/Components/XformComponents.gha
ManagedPlugIns/GrasshopperPlugin.rhp/Components/FieldComponents.gha
ManagedPlugIns/GrasshopperPlugin.rhp/Components/MathComponents.gha
ManagedPlugIns/GrasshopperPlugin.rhp/Components/SurfaceComponents.gha
ManagedPlugIns/GrasshopperPlugin.rhp/Components/VectorComponents.gha
ManagedPlugIns/GrasshopperPlugin.rhp/Components/ScriptComponents.gha
ManagedPlugIns/GrasshopperPlugin.rhp/Components/Microsoft.CodeAnalysis.Workspaces.dll
ManagedPlugIns/GrasshopperPlugin.rhp/Components/Microsoft.CodeAnalysis.dll
ManagedPlugIns/GrasshopperPlugin.rhp/Components/IOComponents.gha
ManagedPlugIns/GrasshopperPlugin.rhp/Components/PTComponentLibrary.gha
ManagedPlugIns/GrasshopperPlugin.rhp/Components/Kangaroo2Component.gha
ManagedPlugIns/GrasshopperPlugin.rhp/Components/KangarooSolver.dll
ManagedPlugIns/GrasshopperPlugin.rhp/Components/GhPython.gha
NodeInCode.dll
AMDDenoiser.Mac.rhp
bullant.rhp
bullant.dll
bullant.gha
dynamic/unknown
?, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null
Anonymously Hosted DynamicMethods Assembly, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null
Snippets.scripting, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null
/Users/ghalibouayad/Library/Application Support/McNeel/Rhinoceros/7.0/Plug-ins/Grasshopper (b45a29b1-4343-4035-989e-044e8580d9cf)/Libraries/
Topologizer.gha
yellow_0.gha
MeshTools.gha
Parakeet.gha
4d-noise-1-0-0.gha
Tree8.gha
anemone1.gha
shortestwalk-1-5-2.gha
heteroptera_1.gha
Pufferfish3-0.gha
voxelizer.gha
Exoskeleton2.gha
PlanktonGh.dll
Plankton.dll
Rabbit.gha
Chromodoris.gha
Cocoon.gha
Meshedit2000.gha
MeshMachine.gha
Element_1.1.gha
sandboxtopology.gha
SuperDelaunay.gha
Fattener.gha
moonlight1-0.gha
Parakeet.ghpy
/Users/ghalibouayad/Library/Application Support/McNeel/Rhinoceros/7.0/Plug-ins/Grasshopper (b45a29b1-4343-4035-989e-044e8580d9cf)/Libraries/Dendro/
DendroGH.gha
/Users/ghalibouayad/Library/Application Support/McNeel/Rhinoceros/7.0/Plug-ins/Grasshopper (b45a29b1-4343-4035-989e-044e8580d9cf)/Libraries/fox/
Aggregations.gha
Aggregations_Core.dll
Graph_GH.gha
GraphLibrary.dll
/Users/ghalibouayad/Library/Application Support/McNeel/Rhinoceros/7.0/Plug-ins/Grasshopper (b45a29b1-4343-4035-989e-044e8580d9cf)/Libraries/Culebra_GH/
Culebra_2.0_GH.gha
IKVM.OpenJDK.Core.dll
CulebraData.dll
/Users/ghalibouayad/Library/Application Support/McNeel/Rhinoceros/7.0/Plug-ins/Grasshopper (b45a29b1-4343-4035-989e-044e8580d9cf)/Libraries/LunchBox/
LunchBoxML.gha
abort() called
*** Terminating app due to uncaught exception ‘NSGenericException’, reason: ‘-[NSApplication runModalSession:] may not be invoked inside of transaction begin/commit pair, or inside of transaction commit (usually this means it was invoked inside of a view’s -drawRect: method.)’
terminating with uncaught exception of type NSException
Application Specific Backtrace 0:
0 CoreFoundation 0x00007ff814d91f0b __exceptionPreprocess + 242
1 libobjc.A.dylib 0x00007ff814af2b9d objc_exception_throw + 48
2 CoreFoundation 0x00007ff814d91d6f +[NSException raise:format:] + 189
3 AppKit 0x00007ff817fc6835 _NSRunModal + 152
4 AppKit 0x00007ff817b6d1bc -[NSApplication runModalSession:] + 241
5 ??? 0x000000019e45bae1 0x0 + 6950337249
Thread 0 Crashed:: tid_103 Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x7ff814c19112 __pthread_kill + 10
1 libsystem_pthread.dylib 0x7ff814c4f214 pthread_kill + 263
2 libsystem_c.dylib 0x7ff814b9bd10 abort + 123
3 libc++abi.dylib 0x7ff814c0c0b2 abort_message + 241
4 libc++abi.dylib 0x7ff814bfd1fd demangling_terminate_handler() + 266
5 libobjc.A.dylib 0x7ff814afa509 _objc_terminate() + 96
6 libc++abi.dylib 0x7ff814c0b4d7 std::__terminate(void (*)()) + 8
7 libc++abi.dylib 0x7ff814c0df3b __cxa_rethrow + 99
8 libobjc.A.dylib 0x7ff814b03e46 objc_exception_rethrow + 37
9 AppKit 0x7ff817fc6a08 _NSRunModal + 619
10 AppKit 0x7ff817b6d1bc -[NSApplication runModalSession:] + 241
11 ??? 0x19e45bae1 ???
Model: MacBookPro15,1, BootROM 1715.60.5.0.0 (iBridge: 19.16.10647.0.0,0), 6 processors, 6-Core Intel Core i9, 2.9 GHz, 32 GB, SMC
Graphics: Intel UHD Graphics 630, Intel UHD Graphics 630, Built-In
Graphics: Radeon Pro 560X, Radeon Pro 560X, PCIe, 4 GB
Display: Color LCD, 2880 x 1800 Retina, Main, MirrorOff, Online
Display: HP Z23n G2, 1920 x 1080 (1080p FHD - Full High Definition), MirrorOff, Online
Memory Module: BANK 0/ChannelA-DIMM0, 16 GB, DDR4, 2400 MHz, SK Hynix, H5ANAG8NAMR-UHC
Memory Module: BANK 2/ChannelB-DIMM0, 16 GB, DDR4, 2400 MHz, SK Hynix, H5ANAG8NAMR-UHC
AirPort: spairport_wireless_card_type_wifi (0x14E4, 0x7BF), wl0: Jul 12 2021 19:26:30 version 9.30.464.0.32.5.76 FWID 01-45ccefcd
Bluetooth: Version (null), 0 services, 0 devices, 0 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
USB Device: USB31Bus
USB Device: USB2.0 Hub
USB Device: 2.4G Wireless Mouse
USB Device: USB-C Digital AV Multiport Adapter
USB Device: USB3.0 Hub
USB Device: T2Bus
USB Device: Touch Bar Backlight
USB Device: Touch Bar Display
USB Device: Apple Internal Keyboard / Trackpad
USB Device: Headset
USB Device: Ambient Light Sensor
USB Device: FaceTime HD Camera (Built-in)
USB Device: Apple T2 Controller
Thunderbolt Bus: MacBook Pro, Apple Inc., 47.5
Lets try GrasshopperLoadOneByOne command and see if we can figure out which might be causing the issue. I’m surprised that all those plugins have mac versions. Pufferfish is typically really stable but can be installed improperly, lets start with that one.
Hello Japhy ! Brilliant… loaded one by one… and pushed No for the plugins that were on the edge of functioning… So far Gh is back to normal and I am able to put components on the canvas again without crashing ! Pufferfish is operating normally.
Removed are :
Culebra2.0
Crane
Bullant
and Sunglasses…
In the error report, on the lines you can read error next to sunglasses… So I suspect it comes from that. anyway, I will run again and will let you know which one is causing !
With thanks !
