Grasshopper hangs on load
Hello
My Rhino 8 Grasshopper always hangs for a minute on first startup while showing the following :
and simultaneously Rhino status bar (greyed out because of window freeze):
(Obviously no gh script loaded at that time).
Does that happen to someone else?
Does anyone know the root cause? I have the impression that the hang is getting longer each time…
Hi Raphael,
This is most likely a conflict of some sort.
A quick quick troubleshooting method is to start Grasshopper with the GrasshopperLoadOneByOne command.
or
  • Navigate to %AppData%\Grasshopper\Libraries and temporarily remove all third-party plugins
  • Restart Rhino and reopen GH to see if the hang persists
  • Re-add plugins one by one to identify the culprit
Thanks!
Took me some time to find how to use GrasshopperLoadOneByOne efficiently. Had I known that it copies the last accepted (Yes button) plugin’s path to clipboard would have saved me many tries…
In the end it appears that :
The Python & Markdown loading is triggered by byRhinoGadget (including latest by PackageManager), and takes 10-20s to load.
The hang actually happens a few plugins later, namely the bundled GhPython, which takes over a minute to load!
But after uninstalling byRhinoGadget… GhPython loads in a few seconds. So the former is indeed the culprit in its impact on GhPython.
Why exactly, I don’t know.
Well that wasn’t the end of the story. After a restart, Grasshopper still hangs about a minute after I say Yes inGrasshopperLoadOneByOne for GhPython
@Japhy Are there any known issues for GhPython ?
