Hi, I built a Model with grasshopper and now I want to start rendering but the Problem is that I can’t open my saved Rhino file and export it to Twinmotion properly Even when it says ‘synchronizing completed’. When I switch to Twinmotion I can’t See my anything. Do I have to bake everything or just the meshes or something else? Or change the Settings? Thx in Advance.
Hi - Yes, you will have to bake your objects to the Rhino document. As for meshes, Twinmotion will only use meshes but, if you have a viewport in a shaded display mode, your NURBS geometry will automatically generate display meshes that Twinmotion can use.
HTH,
