Twinmotion plugin
When I use the Twinmotion plugin to export a Rhino 6 model I can only select the Rhino objects in Twinmotion but not move, rotate, or scale them. If I export the Rhino model as an fbx file and import that file into Twinmotion I don’t have any problems with moving, rotating or scaling. Any ideas?
Thanks,
Dennis
I think both of those methods product different objects types. But, you would need to find out from Twinmotion directly:
They would know.
It is because Rhino is master of the link, so move it there and update. Or export as fbx if you want freedom.
That said, I really wish Rhino could add a «set object pivot to object boundigbox bottom center» on export as an option.
Rhino’s lack of object pivot points is very limiting.
(To work around that you have to move the object to 0,0,0 and export the object to a separate fbx file. That way you can move it as a native TM object. But that is not a good way to work if you have many objects)
