Grasshopper decreasing dot pattern
Hi I am trying to create vanishing dot pattern dense in the middle.I have created the middle point as I wanted but the ending is not vanishing. I have attached the script. Can anyone help me with it. thank yoou for reading.
20240109 - Dot Pattern.gh (10.6 KB)
Hi @Hatice_Nur_Bülbül ,
Your GH file didn’t have the surface embedded in it. I made a plane and set three more points to be planar with it. Is this what you are trying to get? Maybe the preview for the Divide Surface component needs to be hidden on your end so you can see the circles.
Hi Brian Thank you for your answer. I am trying to have a vanishing point at the arrow direction but right now the pattern starts to get bigger again. is there a command to define that finishing points. Thank you for your time
Try this…
Multiple_Attractors_Search_Distance.gh (11.5 KB)
Thank you so much. This solves my problem :slight_smile:
